hey guys up for sale is my 01 vu ss ute, its a very regretfull sale but i have to let it go due to commitments with my house.
PRICE $20,500
its tigar mica in colour
lowered on king springs sss low in the front and lovells in the rear
20inch rims with crome inserts
brand new tyres fitted 2 days ago
saas adjustable racing bucket seats on standard rails so its legal
hsv cluster
vy hand brake
vy gear knob
vy leather gear stick boot
in dash dvd player, full touch screen!
big stereo (2x amps, 6x9's, 6.5's, tweaters and a sub
tub liner with rubber inset
DBA cross drilled and slotted rotors all round (less then 1000kms old)
ls6 manifold
pacemaker extractors
twin 2.5inch exhaust with 1 resinator in each side and 4inch dump pipes out each side at the rear (sounds awsome!)
6 speed gearbox (perfect condition, very tight and no noise or crunches)
CS8 ripshifter
tex Z grip clutch (made for street and strip, big hp rating)
lightend flywheel
K-Mac 4 point adjustable camber kit in the rear
maffless tune
over the radiator cold air induction kit with K&N filter
the car is spot on, ive never had a problem with it since ive owned it.
it has a full service history by holden (with books)
108,000kms on it but only says 44,000 because its got the hsv cluster in it now
the car past a road worthy just over a monthe ago ( because i got defected for the exhaust)
i will also give the buyer the standard parts like, genuine standard holden exhaust, standard springs and the airbox. no air flow metre as i lent it to a mate and never seen it or him again..
the car has never been in an accident or any thing and a vic check is more than welcome.
there is one problem with the car, 2 months ago some little sh@t keyed the left hand door and part of the rear panel! ive had a few quotes done up and it is on the 800 mark to fix..
pics can be seen here http://forums.justcommodores.com.au/member...ar-pickies.html
my number is 0412285096 you can call or txt, cheers
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
