Complete 32 Gtr Wrecking, Perfect Interior, Aftermarket Parts, All Panels, Nismo Wheels,with Semi Slicks, 33 Gear Box Nismo Dash
Hi, Clutch push or pull? Price?
Also need all 4 abs-sensors and lower radiator hose. Price if not sold?
Best regards
Petter, from Norway
  • Replies 104
Posted Images
The sensors are in the hubs, only one small screw that holds them in place.
Petter
Hi Petter
I will check it out I gather you can't PM
Cheers
Hi Petter
Cheers
Radiator, shroud and lower bar is sold, yell out if you are after anything else best to PM or get in contact by phone 0408 188 777.
Cheers
Updated add, if I have mssied amyone with PM etc just yell out, Regards Taylor 0408 188 777
Cheers
Panels
Guard Driver side great condition 275
Left door includes hinges & lock and handles 160
Right Door includes hinges & lock and handles 160
Side Skirts with pods 300
Window mechanism with motor 100 each
Rear Bumper 200
Rear Reo 175
Interior, great parts for cleaning up your interior
Door Trims Great colour Front and back including all clip handles 300
Centre surround around stereo and Aircon 100
Glove Box with Key 70
Centre Console including glove box lid, strong colour 120
Leather Gear & Hand Brake Genuine great condition 80
Dash No bubbles/lifting two small screw holes easy fix, hard to notice 150
Carpet 120
Mats 100
Roof lining perfect 90
Boot complete including plastic and trims 170 no stains
Glass
Front windscreen with all wiring and aerial, genuine 475
Rear windscreen with all wiring, Genuine GTR thinner & lighter 575
Drivers side quarter glass 130
Passengers side quarter glass 130
Light & Indicators
Head Light Passenger side standard 90
Head Light right Driver side standard 90
Gauges
Greddy Exhaust gauge and wiring 120
Climate Control 90
Wheels
Space saver 45
Drive Line
Gear Box 33 GTR Good condition fits 32 as well , on Hold 900
Twin plate Direct Racing Clutch, great for performance & daily low klm 1180
Front Diff 270
Rear Cradle 350
Tail shaft 200
Drive shafts with boots 120 each
Suspension
Lower control arms factory with N1 brake ducting 100
Front sway bar 80
Rear hubs 190
Engine Bay
ABS Unit 350
Brake Master cylinder 180
Starter Motor 150
Power Steering Reservoir 90
Coolant bottle 45
4WD Computer 120
Engine Harness $600 new sell at half 300
Full Body Harness, inc fuse box, no cute TBA
Injector & resistor pack TBA
Air flow meters 145 each
HKS air pods including arms and braces 180 set
Exhaust cat back, pretty big need to measure part stainless 580
Miscellaneous
Fuel Door 60
Fuel tank 70
The 3 centre gauges, you know voltage, boost and water temp one.
It has its own wiring to it and that is what i need, the plug that plugs into it. so yea you need to cut it.
Think you can remove it? if so how much you want?
cheers!
Edited by VXL
cheers!
Hi, I want to sell the harnes complete with no cutting
Zardos I will get back to you today
Cheers
Ok, but the only easiest way you can remove it is by cuttin the wire.
Let me know if you reconsider!
Cheeers
still got the Recaro seat?
VXL, harness has already been removed without cutting so sorry not keen to split.
Seat already sold PM sent
Dash sold
Cheers
  • 6 months later...
Door Trims sold and carpert sold, feel free ot yell out about remaining parts
Cheers
Hey Taylor
Keen on Centre surround around stereo and Aircon
Can you please post -> Canberra 2905
Please pm acct details
S!N
0404 822 143
Hi Guys
Reverse lights are sold an dI will get in contact with you Sin regards the Air Con
Cheers
    • A quick google, and some E39 users have found pulling my sensor out/apart and cleaning it alleviates their issue. Then get the oil warning to go off, and once it is off (from the sensor saying it was unhappy) some find they can just unplug it and it is happy to just keep going now. Maybe give it a crack? If you can actually pull the sensor apart, hit it with some electrical contact cleaner.
    • Yep. In the E39 it's slightly different than the others. Honestly I'd just leave it but every time I drive the car it tells me oil is low and that just makes me check the dipstick. It is a BMW Afterall and it tries to expel it's own oil regularly.  Thankfully it's not like my E90 that has no dipstick at all so you just gotta trust it.
    • Was that also a typo? $350?! Just typing "BMW oil level sensor" and prices start out a lot more sanely than $350. I'm guessing it's a sensor used in one low volume model only or something?
    • They kept the product number the same, so we "didn't pick it up when packing your order". If you packed the order, you clearly saw the box wasn't Hella...
    • Actually, the equivalent skyline part is both cheaper and simpler, maybe you should come back from the dark side?
