Details bout the car??
wat motor??
mannual or auto??
wat has done to it??
well its a 1988 nissan cefiro,
rb20det manual with an r33 turbo, hybrid front mount
single heavy duty clutch
short shifter
pod filter
the interior is stock and is probably the cleanest one i have ever seen.
has a full competition stereo
was lookin at putin an rb25 in it soon but if i did that i would have to sell it for 15,000
https://www.sau.com.au/forums/topic/284596--/#findComment-4793478
  • 4 weeks later...
post-61127-1237959513_thumb.jpgpost-61127-1237959533_thumb.jpgpost-6290-1123088824.jpgpost-61127-1237959580_thumb.jpgpost-61127-1237959593_thumb.jpgpost-61127-1237959604_thumb.jpgpost-61127-1237959615_thumb.jpgpost-61127-1237959658_thumb.jpgpost-61127-1237959700_thumb.jpg[
a
ttachment=213801:DSCF3359.JPG]post-61127-1237959026_thumb.jpg1988 Nissan A31 Cefiro
$10,000
must sell, price drop, regretful sale...
engine:
3" cat back exhuast with 2-1/4 twin tip
R33 turbo with braided hoses
hybrid front mount intercooler
turbo smart blow off valve
pod air filter
adjustable camber arms
new brake master cylider
turbo timer
interior:
spotless and very clean never seen one cleaner
new short shifter
small racing steering wheel
New exedy heavy duty single plate clutch
STERIO:
JVC touch screan double din dvd player
earthquake 600watt front splits
hurts 250watt 6" rear speakers
2x12inch Polk Momo 1600watt subs in custom made box for better sound
earthquake 900watt 5 channel
earthquake 4000watt cap
fully dynomated
exterior:
full uras body kit with front wide fenders
cutsom gold with rainbow flake paint
18 x 8 black and chrome akuza rims
with 235/40 at the front and 245/30 at the rear
exelent grip turns corners like its stuck to the road
is that all the same?
https://www.sau.com.au/forums/topic/284596--/#findComment-4840379
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
