Details bout the car??
wat motor??
mannual or auto??
wat has done to it??
well its a 1988 nissan cefiro,
rb20det manual with an r33 turbo, hybrid front mount
single heavy duty clutch
short shifter
pod filter
the interior is stock and is probably the cleanest one i have ever seen.
has a full competition stereo
was lookin at putin an rb25 in it soon but if i did that i would have to sell it for 15,000
https://www.sau.com.au/forums/topic/284596--/#findComment-4793478
  • 4 weeks later...
post-61127-1237959513_thumb.jpgpost-61127-1237959533_thumb.jpgpost-6290-1123088824.jpgpost-61127-1237959580_thumb.jpgpost-61127-1237959593_thumb.jpgpost-61127-1237959604_thumb.jpgpost-61127-1237959615_thumb.jpgpost-61127-1237959658_thumb.jpgpost-61127-1237959700_thumb.jpg[
a
ttachment=213801:DSCF3359.JPG]post-61127-1237959026_thumb.jpg1988 Nissan A31 Cefiro
$10,000
must sell, price drop, regretful sale...
engine:
3" cat back exhuast with 2-1/4 twin tip
R33 turbo with braided hoses
hybrid front mount intercooler
turbo smart blow off valve
pod air filter
adjustable camber arms
new brake master cylider
turbo timer
interior:
spotless and very clean never seen one cleaner
new short shifter
small racing steering wheel
New exedy heavy duty single plate clutch
STERIO:
JVC touch screan double din dvd player
earthquake 600watt front splits
hurts 250watt 6" rear speakers
2x12inch Polk Momo 1600watt subs in custom made box for better sound
earthquake 900watt 5 channel
earthquake 4000watt cap
fully dynomated
exterior:
full uras body kit with front wide fenders
cutsom gold with rainbow flake paint
18 x 8 black and chrome akuza rims
with 235/40 at the front and 245/30 at the rear
exelent grip turns corners like its stuck to the road
is that all the same?
https://www.sau.com.au/forums/topic/284596--/#findComment-4840379
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
