I can't see jack on the radio or aircon info control panels in the daytime , it's driving me nuts, they both light up so it's not the fuse but they're dimmer than a 2 day old cretin.
I can't find a dimmer switch for the dash lights anywhere, its not on the lights control stalk or a separate one in the dash near the trip reset stalk IFiIK where the damn thing is.
It's a 98 R34gt-T can anyone help ?
https://www.sau.com.au/forums/topic/284636-cluster-dimmer-r34/
Normally when your headlights are on the air con and other dash lights are dimmed automatically.
Could it be that when they complienced your car they changed the headlights and the dash now thinks the lights are on all of the time and have the dim setting as a result. How you fix this is another question - just another option to investigate.
Thanks for that, when the lights are on I can actualy see the functions (just), they dont appear to backlight atall in normal daytime driving they're hopeless, do you know if they are supposed to, the headlights are zenon something ? and appear stock but who knows , it's in having a bit of a suspension check and underneath bolts tighten at Auto-tech today so I'll ask the guys and see what they know when I pick it up.
:down:some days I know eveything, some days I know nothing, if only I could remember which is which.
the easiest way to test victory's theory is to turn the key to ON at night, then while looking at the lights, turn the lights on. if the lights in the aircon, etc, don't dim then you know that is the problem. if they do, then you know there is something else going on.
also not all cars get dimmers fitted when they are complied. my r33 never had one, and neither did my 180sx. the ones that i have seen that have had them fitted are the stalk type. they have a post that sticks out with a knob on it (unlike the factory fitted ones that are a roller type). i have seen them located anywhere from either side of the dash near the base of the steering column to down near the fuse panel on either side of the steering column.
Each component has a wire you can cut to kill the dimming. Just pull up a wiring diagram, the wires from each component will run back to the same point. I cut the ill. trigger wire on the clock in my Maxima so its always fully illuminated when I drive with my headlights on.
Well problem solved, asked Gavin at Auto-tech, there is no dimmer and the dash lights only come on with the main lights when you're using them at night, I gotta say if this is the worst problerm I'm gonna be have I'll be very happy. :D
If I can find a wiring diagram I'll hoy it to an auto sparks and see if they can do anything without to much hassle if it's a drama I just aint going there.
Thanks for the replys guys :D
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
