hey guys i have only had the car for about 5 months being the second owner in Aus it's been a great and fun car but I am not in a hurry to sell.
car is extremely quick
triptronic
6a13tt motor
AYC - just serviced
timing belt done in japan
car has 139,xxxkm on it i purchased it with these modifications
Greddy front mount Intercooler
full fujitsubo exhaust (turbos back)
tien ha coilovers
mines chipped rom
apexi boost gauge
greddy profec b boost controller
I have added \ replaced
evo 7 17 x 8 with about 80% tyres
rolled guards
BMC air filter
Evolution 8 brembos front and back with endless pads
retrim back seats in leather and suede
door trims retrimed in black suede
IFS sensor replaced
spark plugs replaced
top gun leads
Crank angle sensor replaced
and torque converter seal replaced + motul atf1a fluid
car has a few scratches and tics in the bumper thats all thats wrong
$14,500 :down:
car has rego till jan
cheers
0402670354
https://www.sau.com.au/forums/topic/284791-fs-1998-legnum-white-modded/
hey mate i have not had the car dynoed but looking at the 170-180atw mark
and car runs great as it should :P
That's a pretty decent gain mate.
I was just wondering as I had a Galant a few cars ago. I was going to modify it, but after doing some research I found out the ecu was pretty anal. Most other people gained fuel mixture problems. Then again mine was a 2000 model, and in the later models the emissions were much more strict.
Anyway you have done the hard yards if it's running well. Somebody buy this if they want a good Legnum!
  • 1 month later...
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
