Hi All, I have these remaining parts up for grabs.I'm located in Adelaide and can organise postage for interstate buyers but at their expense. Pics included below. All parts are still functional and in excellent condition.Send a PM if interested in any of the parts.
PARTS LIST:
-2X fuel rails (1 32GTR, 1 33GTR Vspec) $30 ea
they both come with reg.
-2x Bosch 070 external fuel pumps (from VL) $40
-33GTR Vspec alternator $80
-RB26 heat shields $20
-RB26 exhaust manifolds $80 pair
-RB26 dump pipes $60 pair
-R33GTR Vspec sump with baffle plates and gears $250
-RB26 (33GTR) throttle bodies with linkages $200
-RB26 AAC valve and air chamber $120
-33GTR air flow meters (red label) $200 pair
-RB26 rods and pistons (rods great/2 pistons have ring land failure) $120 for the 6
-RB26 twin turbo connecting pipe $20
-R32GTR harmonic balancer $50
-RB26 idle control valve $80
-Nakayama racing wheels 18x7.5 +32 (BARE RIMS) $800 FOR THE 4
-Manta ray rims 17x9.5 +32 (BARE RIMS) $200 the pair
-brand new regal rubber 17x235/45 $200 the pair
-GTSt centre grill (fresh 2PAK silver) with mesh $150
th_08112009295.jpgth_08022009271.jpgth_08022009275.jpgth_08022009276.jpgth_08022009283.jpgth_08022009282.jpgth_07272009239.jpgth_07272009246.jpgth_07252009236.jpgth_06282009152.jpgth_07122009217.jpgth_06282009161.jpgth_06282009164.jpgth_06282009172.jpgth_05302009087.jpgth_rb26parts028.jpgth_rb26parts033.jpg
CHEERS HULI
PM OR CALL 0400262578
Edited by huli
https://www.sau.com.au/forums/topic/284934-rb26-gtr-left-over-parts/
For all those that have PM'd, Yes the sump comes with baffle plates and diff gears. Its also from a 33GTR Vspec!!!
Shoot us genuine offers on any of the parts, all still for grabs.
MAKE ME AN OFFER ON THE PARTS AND IF GENUINE, THEY COULD BE YOURS!!!
ALL PARTS ARE IN EXCELLENT WORKING ORDER AND NO DAMAGE! QUALITY NOT CRAP!!!!
Edited by huli
GTR SUMP + FRONT DIFF AND BAFFLES ****SOLD**** (JACOB)
FUEL RAILS x2, THOTTLE BODIES AND LINKAGES, AAC VALVE, HARMONIC BALANCER ****SOLD**** PENDING PAYMENT (XR PILOT)
OTHER PARTS STILL AVAILABLE
PARTS LIST:
-2X fuel rails (1 32GTR, 1 33GTR Vspec) $30 ea ****SOLD****
-R33GTR Vspec sump with baffle plates and gears $250 ****SOLD****
-RB26 (33GTR) throttle bodies with linkages $200 ****SOLD****
-RB26 AAC valve and air chamber $120 ****SOLD****
-R32GTR harmonic balancer $50 ****SOLD****
CHEERS HULI
MAKE ME AN OFFER FOR THE REMAINING PARTS!
SHOOT THROUGH SOME OFFERS GUYS & GIRLS!
NEVER KNOW I MIGHT BE IN A GOOD MOOD AND THEY COULD BE YOURS FOR THE RIGHT PRICE!!!!
NO LOWBALERS! THEY WILL NOT GET A RESPONSE!!!!!!!!!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
