I have 265/35/18 on all 4 (18 x 9.5 rims)
Plenty of room for 275s...
But why would you want to?
The 265s tramline like all hell - and the steering is pretty heavy. You've got all the grip you need - no point going wider.
Just my 2c.
Thanks... Jamezilla
I just put some 19's on the the car, & because they were different size widths the ATTESA was going hay-wire. So I was about to order some more tyres but the only size I could get Good Year REV SPEC in was 275 /19 /30. I'll just stick with the originals, they ride so much more better. Spewing coz my rims look FHAT!
Just read your other thread...
275s will fit - provided your suspension is set at factory height. You may need castor adjustment though.
With the 265s on full-lock (with new-improved 'speedboat' suspension) they just clear the splash-panels under the gaurds. Mind you - I have adjustable castor-rods... not sure if they make any good/bad difference though.
I imagine I would still experience some rubbing on tight, speedy turns (not all that common) as the car natuaraly shifts it's weight.
Best you can do is try them. I'm sure the tyre place will let you check them out?
275s are fine.
I was running 275s on my 18x10s for quite some time until I changed tyres to the Azenis ST115 which doesn't come in 275.
I tried it both on stock suspension and my Tien RAs.
As James said though, steering may get a bit heavy though and unless you really need the grip, stick to the 265s.
Just my 2c.
I completely agree.
To be honest with you... dunno what the brand is but I haven't seen any other car with them. I have had them for about 2years, they were originally of my CLK Benz. The offset for the rear is OK, however the front stick a little more into the guard thean normal. Again dunno if this is an issue aswell???
Here are the pics... tried to also get a close up of the rim. PS: Note - these were off my CLK so no smart comments about the Benz / AMG logos :D I planned to change them.
Thanks for the help guys. I ended up fitting the originals this morning & how happy am I ;)
Thanks for the compliment mate.. but I still wipe my own "@ss" so i'm no different to you guys. Let leave the Mums & wives out of this OK :D
- I'm 29
- Got kicked out of school in Year 10
- Property "with my family"
By the way, I haven't picked up E55 yet. 2 more weeks. Though it is the country. Honestly, I prefer driving the GTR, but the E55 is a V8 & nothing sound like a V8 especially supercharged.
Haha - the poor little thing hasn't been out and about for a little while - so maybe there's a twin KGB tractor too!?
Anyway, now you know the car please dont drive over with your Hummer
You know... it probably could get a fair way up the bonnet... if it could catch you :cool:
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
