hi guys,
just wondering if someone can help me identify what a hose does and what i can do with it when i put in a pod filter.
the hose i am talking about is connected to the right hand side of the filter box and apparently connects to some kind of sensor according to one of the guys at autobarn who had a quick look for me.
i will try to get some pictures to help tomorrow or next monday.
https://www.sau.com.au/forums/topic/285037-r34-pod-modification/
I believe I know which one you're talking about. It's a vacuum line.
There's a vacuum assembly towards the back of the engine, two vacuum lines run together past near the power steering reservoir, one of them goes into the airbox, the other one keeps going down to the charcoal canister. The one that goes to the airbox just needs to be tucked away when you remove the box to fit a pod.
Don't block this vacuum line! This vacuum line ultimately connects to the variable air intake control actuator in the intake plenum on RB25DE NEO's. Basically when you look at the intake plenum where the Y piece connects to it, you'll see the rod for the solenoid. Inside the middle of the plenum is a butterfly valve that partially separates the intake into 2 parts. At around 4700RPM this valve in the plenum opens completely. This is to assist with response in the low RPM on the N/A RB25DE NEO Motors. If this vacuum line is blocked, this valve won't function properly and power will be lost. Tucking it out of the way and removing the airbox for fitment of the pod won't effect anything, so long as the vacuum line isn't blocked.
Edited by N-DAWG
Don't block this vacuum line! This vacuum line ultimately connects to the variable valve solenoid in the intake plenum on RB25DE NEO's. Basically when you look at the intake plenum where the Y piece connects to it, you'll see the rod for the solenoid. Inside the middle of the plenum is a butterfly valve that partially separates the intake into 2 parts. At around 4700RPM this valve in the plenum opens completely. This is to assist with response in the low RPM on the N/A RB25DE NEO Motors. If this vacuum line is blocked, this valve won't function properly and power will be lost. Tucking it out of the way and removing the airbox for fitment of the pod won't effect anything, so long as the vacuum line isn't blocked.
thank you for the reply.
so if i understand correctly as long as i do not block it in anyway i do not have to connect it to anything once i fit the pod?
  • 2 years later...
what number is it on the diagram?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
