  • Replies 185
yeah theres a guy trying to convert it hopefuly for me. the footage is going to be played on 9 news tonight and also ten news either tonight or tomorrow night.
Cheers guys for all your help
oh hells yes,
ill make sure im home by 6 for that shit :):D
For those who couldnt play the footage, it will play in media player classic, just download it from google or something. otherwise heres a pic I have a attached of still shots from the footage. thanks cameron as well for your help!
the 2nd image is just an ok shot of the blonde guy
yeah mate the building next to me is where they came from, they entered the carpark from the entrance to the lot by that building. inside job for shore.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
