he Hipermax II coilover suspension kits have been engineered to be track ready suspension that is still "streetable". Dampening and rebound can be adjusted simultaneously in 30 different increments to deliver the desired shock compression and rebound stiffness. Ride height is adjusted by simply rotating the 60mm spring retainer perches around the chromed steel shock body. The dual interlocking spring retainer perches prevent spring movement and unwanted ride height changes.
The included anodized aluminum upper pillowball mounts improve traction and steering response while maintaining suspension geometry. Also certain applications offer camber adjustments on the upper pillowball mounts. All HKS Hipermax II coilover suspension kits include all the needed wrenches, adjustment knobs, and miscellaneous hardware for a complete installation and tuning.
hks coilovers $1150
nismo flywheel $100
r33 strut brace $50
r33 pedders springs 35mm lower rear progressive $100 for 4
contact by pm
i may swap with things of interest
like a roll cage + cash
or ??????????????????
Edited by WARLORD
https://www.sau.com.au/forums/topic/285581-hks-hipermax-ii-coilover-suspension/
up date
8:12 pm
more pm's answered
4 buyer for coil overs who ever is first
1 strut brace
4 flywheel
thanks guy
a exhaust manifold + cash would be a good swap
Edited by WARLORD
