Hey all,
Selling of parts from my R32 GTR, had engine bottom end failure so parting out. Make me some offers on the below :
Whats left :
The interior is pretty much all there EXCEPT for front seats, gear knob and door trim (doors are gone)
Front bar is gone as are the doors and boot lid, the gear box and front bar are gone.
So if it's not on the list below tell me what you're looking for and I will let you know if I have it... most likely will.
RB26DETT head (just been freshened up) $1800 complete.
Igniter pack $50
GTR turbo's, High Flowed BB Steel wheels. never boosted above 6 pounds.
ABS unit $offer?
NFU Coil overs Hight Adjustable (AWESOME ride the car handled like it was on rails) $1000
Stock GTR Cooler $100
Bonnet $550
grill $150
Rear seats (stitching loose up the top on one side) $offer?
Carpet all in good condition : $100
BRAKES : GTR Calipers, NEW DBA slotted rotors (just enough time to run my motor in and blow it up, so about 6000k's on them with no really hard breaking. new break pads (cant remember what brand they are, they are dirty pads but the stop hard. $1000 obo.
Vents left & centre -- $150 pair or $80ea
lower control arms -- $120
castor rods -- $100
Afm’s green label -- $100 ea
tail lights -- $150pair
indicators -- $75pair
3 inch exhaust all the way through (it’s flowy but pretty loud) -- $250
Complete engine harness. Price $250.00
Complete Chassis wiring from the head light to rear lights all fuse boxs etc. Price. $300.00
Gtr dash (buble in the usual spot but in great condition otherwise - $80
Gtr steering colum with ignition barrel. -$150
Gtr brake booster. - $60
Gtr clutch master cylinder with booster. - $50
Gtr brake and clutch pedals. - $30 each
Gtr front upper camber arms. - $100 pair
Gtr front castor arms. - $50 pair
Gtr heater box. - $70 fan - $30
Gtr centre gauges. - $50
Gtr power steering rack. - $100
Gtr power steering pump. - $50
Edited by BlackR32
https://www.sau.com.au/forums/topic/285984-32-gtr-parts-for-sale/
  • Replies 65
Posted Images
hey there,i will take the igniter pack, can u pm your details and price to post to goldcoast,thanks mate
Hey all,
Whats left :
Igniter pack $50
ABS unit $offer?
Bonnet $550
grill $150
castor rods -- $100
Afm's green label -- $100 ea
3 inch exhaust all the way through (it's flowy but pretty loud) -- $250
Replying to all questions above by PM now.
however, the front guards are already gone sorry.
Have an aftermarket exhaust system not the standard one.
Yes my car is the abs model and the kit is still all there.
hey mate, wats the condition of the indicators, could u pm me a pic. if good i will take them if u will post to whyalla s.a 5600
Edited by ballsdeepgtr
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
