GReddy Breather Tank $80 delivered
GReddy R33 Twin Gauge Holder (60mm) $80 delivered
GReddy Inlet Cam Gear $140 delivered
Haltech Boost Solenoid $80 delivered
Tein R33 GTR Bonnet Damper $150 delivered (This will not fit GTS)
Dash Facia $50
Dash vents $5
RH Inner guard $25
Ash Tray $25 delivered (1 available), 1 SOLD
Random switches $5 for all 3
Airbox with filter and snorkel $80 (also available with AFM)
AFM $80
Rear Centre garnish $20 delivered
Drivers Door Insert $30
Rear 1/4 interior Insert $20
Rear 1/4 Window $50
Pick-up is available from Sydney. PM for details
*Items added and sold, updated 18/12/09
https://www.sau.com.au/forums/topic/286326-r33-leftovers-from-project-build/
  • 1 month later...
Just another update, I have been called away for another month inter-state. So I will let everyone know when I'm back and hopefully offload this stuff real cheap :P
  • 1 month later...
  • 3 weeks later...
do you have gauges to go with the pillar?
No, sorry I don't.
hey do you still have the ashtray??? will it fit for r33 srs 2?? if so i want asap if possible.
thank you.
PM Sent
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
