  • Replies 59
I see your Raptor Jesus and raise you an ice age. There isn't any pics of it because raptor jesus and his Canon SLR didn't survive it.
5 Aces, bitches.
raptor jesus needs no slr, raptor jesus has a photographic memory.
whole deck mofo's.
invalid, way too cold for the diesel, 4x4 wouldnt start.
ba-bow LOL. nothing a few additives cant fix :P
Glowplugs bitch!
+1 right there
4WD limiter bash apocalypse. that should crack us out of an ice age
*insert video of the GQ on the dyno at Graham Wests earlier in the year and you'll understand*
What you talking about matty....your GQ completely deplete the whole Ozone layer...it was ROR worthy
but to simplify,
raptor jesus > all.
Can a raptor jesus do this?
and remember -
Outer space exists because it's afraid to be on the same planet with Chuck Norris.
Chuck Norris wins
Some other useful facts:
When the Boogeyman goes to sleep every night, he checks his closet for Chuck Norris.
Chuck Norris doesn't read books. He stares them down until he gets the information he wants.
There is no theory of evolution. Just a list of creatures Chuck Norris has allowed to live.
Chuck Norris does not sleep. He waits.
Chuck Norris is currently suing NBC, claiming Law and Order are trademarked names for his left and right legs.
Chuck Norris is the reason why Waldo is hiding.
Chuck Norris counted to infinity - twice.
There is no chin behind Chuck Norris’ beard. There is only another fist.
When Chuck Norris does a pushup, he isn’t lifting himself up, he’s pushing the Earth down.
Chuck Norris is so fast, he can run around the world and punch himself in the back of the head.
Chuck Norris’ hand is the only hand that can beat a Royal Flush.
Chuck Norris can lead a horse to water AND make it drink.
Chuck Norris doesn’t wear a watch, HE decides what time it is.
Chuck Norris can slam a revolving door.
Chuck Norris does not get frostbite. Chuck Norris bites frost
Remember the Soviet Union? They decided to quit after watching a DeltaForce marathon on Satellite TV
Edited by 4door_Sleeper
Chuck Norris worships Raptor Jesus, he lives his life trying to attain the amount of pure awesomeness spewing from the raptor jesus. so therefore, Chuck Norris < Raptor Jesus
btw, this thread needs moar:
where is your proof? I have photos to validate my claims, what do you have?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
