Hi guys for sale to day is my RB 25/30 it has rebuilt RB30 Turbo bottom end and a standard RB25 head with stage 2 cams. The motor will come with standard 25 intake manifold or for the right price can come with a custom intake, it will also come with a S/S Top mount turbo manifold. the motor has been run in on the engine dyno. I have the invoice for the motor build I just have to find it but will have it for the buyer....
Price: make an offer
https://www.sau.com.au/forums/topic/286755-rb-2530/
  • Replies 42
I have taken parts off of it since the dyno run and it made 236kw but was only running it in didn't want to rev it past 4000rpm and its got VL Turbo pistons
Edited by Charlie4401
https://www.sau.com.au/forums/topic/286755-rb-2530/#findComment-4812352
  • 1 month later...
His name is Raymond Daley and his from Kingaroy in QLD. Im from Melbourne. I transfer $1920 into his account and still not have received my motor or my money back (its been a month). I try calling him and he pretends to be someone else. I contacted the Fed police but they are too slow.
PLZ HELP ME ANYONE. THIS GUY HAS RIPPED ME OFF $2000!
https://www.sau.com.au/forums/topic/286755-rb-2530/#findComment-4935812
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
