Hi been looking thru the forum and couldn't find anything on the auto transmission oil grade required for the R34 GTT auto. And been under the car and found the drain plug but could find the refill plug. And the rear diff oil grade.
Can anyone out there help me out on this?
1) Auto transmission oil grade
2) Auto transmission refill plug location
3) Rear diff oil grade
Thanks ppl for your help.
The re-fill plug for both the diff and g/box should be on either the left or right hand side of each - should be a round plug with a square in-dent.
To fill them up, just take the plugs out and fill it till it starts to overflow, thats when it's full :woot:
Hi syfon,
Ok thanks for the info. But I can't seem to locate the round nut with the square indent. And what is the grade of the oils to be used? I know the rear diff have got to be a LSD compliant oil but what grade?
Thanks
Gazza thanks for correcting me - i mis-read it and assumed it was a manual transmission.
Yes the automatic gearbox has a dipstick tube to fill the gearbox oil - similar to how the engine has a dipstick to check the engine oil.
I am not sure of the oil that needs to be used for the automatic gearbox......
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
