The ID tag would suggest they are GT2530's. It looks similar (the turbo) to what I have on my car (HKS GT2530's), but mine dont have Garrett stamped on them anywhere (just HKS). Could possibly be a HKS 2530 compressor with some sort of Garrett exhaust housing, but im not too sure.
that my friend IS a GT2530 from a GTR....it will have a 2 bolt pattern on the compressor outlet(094housing)....3 bolt pattern are GTS and Silvia housings....
Well I guess you did sell them to me as GT-R ones :cheers:
Thanks to Doughboy's thread
http://www.skylinesaustralia.com/forums/sh...ead.php?t=28787
I was able to see what they should look like
...and with a quick run through photoshop
I've taken a few pics of the rear of a HKS 2835R turbo to suit an SR20 or RB 20/25. They have the same flange pattern as the one fin your first post. Btw thanks for the free plug :)
Edit: Oh the pics are uploaded to the same link in the ad. That 2530 of yours looks like an SR20 one, not an RB20/25 one as the front cover is for the SR's bolt-on inlet tract. The RB20/25's do not have a HKS front cover, rather a Garret one with the front machined out and an aluminium insert bolted into place to accept a hose connecter directly onto it. Will take a pic of a spare RB20/25 one if I can be bothered.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
