Hi All
I am selling my R32 GTR - recently rebuilt engine (i picked the car up today with only 250km on the engine - a further 1250km before the rev limit is taken off and the final tune is done).
I am after $25,000. Have receipts for well over $30,000 for repairs and improvements etc - $16,000 of them at Advan by me.
Email me if interested - I am in Sydney. [email protected]
This car has a host of extras. Recent addition to the family proving to be more difficult to manage than thought. All import compliance docs and receipts available.
Engine firstly rebuilt less than 9000km ago (3000km on it when I bought it) - bad ring assembly and running rich meant I have had to rebuild the engine after owning the car for less than 6000km.
New engine less than 300km - built by Peter Hopkins of Advan Performance. Motor comes with warranty. I am currently running the engine in - just got it back today 9 Sep 09.
Engine
OS Giken Forged Pistons - brand new
ACL Race Bearings- brand new
ARP con rod bolts- brand new
N1 Oil Pump- brand new
Metal head gasket 1.2mm- brand new
New Clutch
Reco Flywheel
Sard 700cc injectors and hi flow fuel rail - less than 2000km
Adj cam gears - less than 2000km
Re-located oil filter - less than 9000km
Splitfire coil pack - less than 9000km
NGK Iridium Plugs - New
Head serviced etc - New
Turbos - Hi Flowed steeel bearing N1 spec - less than 9000km
Apexi pod filter - less than 9000km
Exhaust 4 inch through to HKW Super Dragger muffler - less than 9000km
Link G4 EMS (AFMs no longer needed) - less than 2000km
Turbosmart E-Boost 2 - less than 9000km
HKS Turbo Timer - less than 9000km
Momo wheel
Tinted windows
Pearl Maroon/red paint
Rays 18*10 rims + 98% rubber
Alarm, central locking and anti theft stuff
Interior A1 condition
New Ventilated discs plus race pads
Gearbox and diffs all A1
Some small scratched on front lip and wheels (from my work car pack) - Otherwise paint is excellent
this car is mint! i have seen it driving around! im looking to buy one again! but not right now! so if its for sale when im ready to buy mate, i will be in contact!!!
i miss my gtr which was stolen! think the wound has healed and its time to replace!
best of luck with your sale mate, if someone falls in love with it, the cash will find its way!
bump for immaculate car!
G
The AFMs are still connected to the Apexi pods but are not used by the Link G4. You dont need them. I just have not got around to getting new plumbing.
I will refund your flight from Melbourne to Sydney if you pay over $20,500.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
