wheres the pic?? when i saw the post i thought munro posted but then when i saw ur name i knew it was a model car :cheers: hehe
Sorry dude minor technical hitch, I'll have it sorted in a sec'.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
