Wtb: R32 Gtr/r33 Gts-t Rear Caliper Pins & Clips
Hey guys,
sadly i've run into some bad luck regarding some r32gtr rear calipers i bought from a wrecker.. (long story short i didn't have time to get down there and pick up the pieces that were missing from the calipers and they have since closed down.. *sigh* partly my bad, life is busy isn't it? :) )
anyway! so im after the pins, clips and anti rattle corrugation (the top piece of metal) from either the r32 gtr rear caliper or a r33 Gts-t caliper.. as i assume they are the same.
NO brake pads required.
NO calipers required.
would be great if someone has some siezed up calipers etc. and dont need the clips ect.
(ask your friends! it would be much appreciated! as i do need these ASAP)
Contact: PM me :D
Cheers.
heres a picture of what i need to make it easier ;) (basically the only thing i have are those little tab pieces.. nothing else :P )
im looking to spend around $100 for these.. so yeah.. :)
Edited by sr20de
I know for a fact you can buy these from Nissan for the front calipers as a kit, im not sure about rears but i dont see why not. Have you VIN ready when you call them.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
