Defect Station On Boundary Rd !
Be Warn,
The usual defect station on Boundary Rd near Lower Dandy road is now pulling cars over. They used to target Trucks only but they now must have gotten bored and start pulling cars over as well.
I just got pulled over and almost got a big fine if it wasn't for this TOP COP.
I was driving my sister's car, the rego just expired (1 day), there is slightly camber wear on the inner wall of the tyre. This young COP was ready to book me then the old fella said nah, don't worry i wouldn't do it. The old fella then told me he's letting me go this time but he wouldn't like to see the car again under the same condition.
Mind you i was going to explain but i didn't need to anyway, the rego is PAID i just haven't been bother sticking it on, the tyre was worn but very very lightly.
Hats off to you Sir, its people like you that make us change our attitude toward the law enforcement !!!
https://www.sau.com.au/forums/topic/288223-defect-station-on-boundary-rd/
Mate I would do a check and if car unreg even 1 day. I would issue a fine it's one of the few things we have NO leaniency with. Unreg= No TAC/INS coverage. If it was paid fair enough. I really couldn't care about issuing defects unless car in really bad/dangerous way or owned by known crooks.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
