A pair of Nismo S-tunes rear suspension to suit R34 GT-T.
Great condition, will lower car approx. 20-30mm and provide firmer ride. Ideal for a street car.
Price: $1400, postage as buyers expense
PM, or for direct contact can SMS 0410 511 628
Annie
A pair of Nismo S-tune rear Suspension.
Can fit on 2doors and 4 doors R34 GT-turbo (can't fit on N/A).
Authentic product, made in Japan by Nismo.
No leaking, no damage!
Great condition, as you can see on the pictures.
4 levels of damping force adjustment.
Spring rates R4kg/mm.
Just a heads up Annie half a Nismo coilover kit isn't going to sell for $1400. I saw a full kit for nearly half that.
Good Luck
Great suspension, probably the best setup you can get for the street and even light track duties. I have the same suspension im my R34 GTR.
The GTT suspension fits R33 and R34 GTR's too.
^^ i'm afraid your wrong on that point. R33 REAR suspension is the same as 34 N/A's NOT gtt's.
I'm afraid ur wrong on that point aswell... he was specifying R33 GTR... which in fact, he's correct
R33 GTR, R34 GTR and R34 GT-t are all the same
regards
Edited by Skyline1989
haha point taken! my bad, read it wrong
btw. a new set of these goes for around 2.3K
Edited by lankanboiiR34
These are front suspension....the rear ones are stubbier, have HICAS clips and dont have adjustment dials :)
no, these are 100% rear i have the s-tune suspension in my car, to change the damper on the front ones they are located on the top, and the rear ones as in the pic are the dials on the side of the shock. its the front ones that have the clips, rears have nothing.
and free bump.
and free bump.
Yep definately rears. I have these in my car. Awesome suspension, but second hand $800 just for rears is way too steep. I'd be expecting to pay half that.
  • 3 weeks later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
