Nah, I didnt think so. So ill just need to pick up an aftermarket reg and the correct lines and fittings. Next question, do you have to buy the fitting seperate or is there a kit you can pick up and if not does anyone know what size fittings are required.
Cheers
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4838113
You'll have to buy fittings. I don't know of anybody who makes a kit, but it might be out there. Just look up what the rail and FPR want. I believe I have all -6 stuff. Can you guys order from summit racing down there? I'm a big fan of the Aeromotive stuff, especially their FPR's. I don't really like the Sard or ESPECIALLY the Nismo FPR's.
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4838130
  • 1 month later...
Alrighty guys sorry to bring this thread back from the dead.
Could someone tell me where all the lines go and what other fittings ill need other than the ones listed.
So far ive gathered ill need
2 x 90degree -6 fittings
1 x 120degree -6 fitting
1 x Y piece but not sure if its also -6 and if a barb on each end.
Any help would be greatly appreciated.
Cheers guys,
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4900693
cheapest way to do it would be to only have 1 feed into the fuel rail, block the centre port and have the line to the reg from the other end of the rail. Otherwise you'll need a y block which splits the single fuel line that runs under the car into two -6 lines that feed each end of the rail.
I buy most of my fittings from www.summitracing.com as it usually works out to be the cheapest (delivery is usually between 4-7days). The other place i use is www.mscn.com.au if i need fittings the next day (overnight express post)
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4900767
Not to fused about the price as ill buy all the fittings through my work. Now the line that comes from the bottom of the FPR which goes to the tank how long does that line have to be and what fitting would be on the end of it to join ( fuel tank end ).
Any links to what the y block connection will be like
Cheers
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4900822
Cheers
The line from the bottom fo the reg (return line) will need a -6 45deg fitting that screws onto the reg, and the other end just clamps over the std fuel line. Line length approx. 1m.
These are the y block's i use - http://www.summitracing.com/parts/EAR-100181ERL and then you just use a 3/8 NPT barb fitting on the other end and run rubber hose between the fuel filter and the std hard tubing.
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4900842
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
