  • Replies 47
I'll check it in the next couple of days - Christian i know made some changes to the forum and trader setup (with paypal)
Might be affecting the donations thing as well as it it all in the same system.
Sit tight, we ain't running with your pennies :)
All good bro, the more its brought to attention, the faster it can be fixed!!
I just want flood control gone and PM sorted.
waiting for Christian to confirm DD :P
Found anything yet Nismoid?
yep - your payment never came through, first time i've seen that happen!
Member Name 	Email 							Package 			Paid 	Started 				   Expires 	Status
30three		 big**_*@hotmail.com 			  Since Deleted 	 0.00 	7th September, 2009		  N/A			DEAD
eh..easy come easy go.
So does that mean you have or have not made a payment?
Because if its not at this end... then i wonder where it might have gone?
wlade666 - Im in SYD this weekend and meeting with C, i will ask then for you.
Okay this is really starting to piss me off. I have to wait between each PM and its quite annoying, I made my donation, and yet my problem isnt resolved, I understand people that run this forum are busy which is fine, but it doesn't take any more than 5 mins to log into your bank account, go yep I see that there, go back to mod options on forum, and change my clearance.
Thanks in advance Prank and other SAU staff!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
