the consult port is on the drivers side in the fuse box (a bit above above the accelerator pedal)
as for oils, really depends on what type of driving you are going to do. do a search, there are plenty of threads on it. as for filters, i just used a ryco filter on mine.
https://www.sau.com.au/forums/topic/289034-diagnosic/#findComment-4840142
Hey my car misfires alot, when i pull the engine to the max it seriously misfires, and when I try overtaking cars in the highway it doesn't stop misfiring, sometimes the boost starts pumping up and the rpm starts dropping no matter what I do till the car slows down, I have stock headers, turbo, trubo dump pipe, down pipe and suddenly a 3 inch exhaust pipe.
I changed my fuel pump, my plugs, my airflow meter which helped for a coupe of days but then it started again.
Help!!! when I start the a/c my engine starts stalling, and at idle my engine starts to dying out especially with a/c.
I broke my hoses that carry oil from above the engine where do i get the newer one?
Waiting for reply,
Falah
https://www.sau.com.au/forums/topic/289034-diagnosic/#findComment-4847750
ok, well the missfire isn't going to be helped by having a broken breather hose. i would go to your spare parts store and take the old hose in and get a piece of hose as close to the original as possible.
then i would look at the coil packs. they are probably stuffed and the major cause of the missfire.
as for the idle not being any good when the aircon is turned on, i would clean the AAC and IAC valves. do a search on here and you should find info on where they are located and how to clean them
https://www.sau.com.au/forums/topic/289034-diagnosic/#findComment-4847771
+1
+1
+1
This guy is right on the money. The heater hose and AAC clean are both easy to do and all up with running around might take half of your saturday. The coilpacks (taking out, inspecting, and taping/siliconing together) would take the rest of your saturday hahaha. A day well spent I'd say.
https://www.sau.com.au/forums/topic/289034-diagnosic/#findComment-4857758
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
