the consult port is on the drivers side in the fuse box (a bit above above the accelerator pedal)
as for oils, really depends on what type of driving you are going to do. do a search, there are plenty of threads on it. as for filters, i just used a ryco filter on mine.
https://www.sau.com.au/forums/topic/289034-diagnosic/#findComment-4840142
Hey my car misfires alot, when i pull the engine to the max it seriously misfires, and when I try overtaking cars in the highway it doesn't stop misfiring, sometimes the boost starts pumping up and the rpm starts dropping no matter what I do till the car slows down, I have stock headers, turbo, trubo dump pipe, down pipe and suddenly a 3 inch exhaust pipe.
I changed my fuel pump, my plugs, my airflow meter which helped for a coupe of days but then it started again.
Help!!! when I start the a/c my engine starts stalling, and at idle my engine starts to dying out especially with a/c.
I broke my hoses that carry oil from above the engine where do i get the newer one?
Waiting for reply,
Falah
https://www.sau.com.au/forums/topic/289034-diagnosic/#findComment-4847750
ok, well the missfire isn't going to be helped by having a broken breather hose. i would go to your spare parts store and take the old hose in and get a piece of hose as close to the original as possible.
then i would look at the coil packs. they are probably stuffed and the major cause of the missfire.
as for the idle not being any good when the aircon is turned on, i would clean the AAC and IAC valves. do a search on here and you should find info on where they are located and how to clean them
https://www.sau.com.au/forums/topic/289034-diagnosic/#findComment-4847771
+1
+1
+1
This guy is right on the money. The heater hose and AAC clean are both easy to do and all up with running around might take half of your saturday. The coilpacks (taking out, inspecting, and taping/siliconing together) would take the rest of your saturday hahaha. A day well spent I'd say.
https://www.sau.com.au/forums/topic/289034-diagnosic/#findComment-4857758
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
