  • Replies 55
Nice work!! Thats very good going, my large can actuator is due to arrive this week :bunny:
Hey Lithium has that box arrived yet.
Looking forward to your results after the rigmarole you've had with prv's and ebc's and so on.
ok so shipping from ATP is $95 - f**k that!!! Is that what you paid conan? It would cost them $20us max for express
I spoke to MTQ they have a "small can" 19psi actuator there for $135 does that sound like it would do the job?
I am getting my car tuned in a couple of weeks and want to try remove every possible weakness before it goes on the rollers
RB30DET with internal gate XR6 GT35R currently holding 15psi with the standard actuator but next tune i want to up it to 22psi so thinking I will need the higher PSI actuator
What is the benefit of "Large Can" ?
i have a spare small can 19psi sitting here tha'll i'll post to you for $134.99. ask mtq to price match that shit
Haha cheers mate, me too - obviously :laugh: The big can actuator sounds very promising... though its a fair bit of boost on the stocker RB25! :)
The actuator is coming back from the US with a mate of mine, he actually bought it while he was over there and threw it in his luggage so no freight :laugh: He left the US on Wednesday so I guess I should be able to grab it this weekend.
funny you mention it the one they have is in perth!
Are you trying to say it shouldn't cost $135?
na thats about what they cost new. i got given a 2nd hand one for free from a mate because he thought it was a 1 bar, which is what i needed, but turns out its 19psi, bit too much for me at the time.
^^^Thanks mate...
Just out of interest...i'm running a 3076R on a 2JZ (so its similar to a 3076 on a rb25/30)...and i've managed to get the car tuned but its still running the standard small can actuator that the turbo comes with...i've attached the graph of boost response below...it seems to be ramping up to full boost by 3300rpm and holding 18psi perfectly...i was wondering if you guys think there will be more gains in boost response with a large can actuator?
take the vac line off the actuator and make sure the gate stays shut then see what rpm you hit the same boost at. dont keep going tho. thats a pretty nice boost graph already tho
Thanks mate...i'll give that a go sometime...its pretty responsive as is but if i can get full boost even sooner that would be great...i went with this setup mainly because i wanted response and midrange anyway...
I just remembered that i'm acutally running next to no preload on the actuator at the moment too...i might shorten the rod slightly to see if there are any gains too...
^^^ Thanks...i know that...it also increases the pressure on the flap so it takes more before it starts to crack open...
I actually gave the actuator rod a couple of turns today...boost response seems a tad better down low...might keep going a turn at a time till it starts to creep upwards...i guess a big can actuator might not be needed for now...
very nice boost curve there limpus!!!
what kind of power you making?!?
Power is very disappointing at the moment...only at 280rwkw at 18psi...this is through a restrictive 2.5" muffler...when I find another exhaust system i'm happy with i'll hit the dyno again for a retune...but at least for now its pretty responsive for a daily...
  • 1 month later...
Another happy user of the big can actuator, here :D Well at least so far...
I took it out for a blat yesterday with it connect, and with my pressure relief valve and AVC-R completely removed from the picture and preload wound right down. With it like that, it hit around 13psi peak which was nice to know.
I then wound some preload into it to get it up to around 15psi, and this is where things started looking really good. Without any extra boost control I was able to reach 1bar by around 3700rpm. This was impossible with the old actuator without removing the hose!
I decided to leave the messing around with the boost control to see if I could make it climb to 16-17psi with any stability (I couldn't reliably with the old setup) for the morning commute, which resulted in me being able to give some words of wisdom to others who are bad in the morning.
DON'T replumb your boost control setup in the morning if you are not a morning person. My vacuum hoses are too short to reach from the AVCR solenoid to the actuator now as I split them to put the pressure relief valve in between. Because I wanted to play, I just wound the pressure relief valve right down (I triple checked I was winding it the right way, and I was) and used it to join the hose so it could reach and all seemed well.
I went out and gave it a quick squirt - which resulted in this: Moby2bar.jpg
Oops. Nothing departed block or anything, so hopefully no harm done - in theory I have a boost limit of around 18psi so the rest of it should in theory have gone into the plenum but not joined with any fuel to make bad stuff happen. Still a bit of a fright though!
I went back to the engine bay and remembered the pressure relief valve (unlike regulators) have to be aligned with the airflow, otherwise it will be permanently closed. My bad. I spun it around the other way and went for a slightly more tentative drive, and to my joy the thing seems to spool every bit as well as with the pressure relief valve in there - but once full boost is hit, it holds much more consistantly!
So far so good, next stop... dyno tune :)
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
