got a vented C/F bonnet for a series 1 (included with pins), its only a couple of months old selling as i need cash for a computer.
check out my thread here:
http://www.skylinesaustralia.com/forums/R3...be-t288317.html
cheers, leigh
cheers, leigh
Yeh seen your car before leigh when cruising with Beza one night with the JDMCOP and JUCY 180 a couple of weeks back, all good though already have a c/f bonnet on order atm
Cheers though, good luck with the sale, was lookin at the style bonnet you've got a while back but didnt get it
If this means anything...don't forget to get some bonnet pins on there...this is a must...although it may or may not happen...without my bonnet pins, I really cannot drive without stressing that it will fly upwards and hit my windscreen...worth investing in...
Isn't the original bonnet latch strong enough to hold it down?
  • 3 weeks later...
from all accounts on here it seems to be that the CF bonnets dont have as much ribbing or rigidity as the stock metal item, so the original bonnet latch is strong enough to hold the front middle section of the CF bonnet but the bonnet flexes when it gets wind under it at speed and front corners lift up...
got the aerocatch latches from vsport.com.au so the cars in ready to be fitted, as for c/f bonnet no longer need one as I've got one now
Cheers guys
as for latch, some ppl have had bonnets pop up and hit their windscreen, not necessarily everyone but its just better option to fit them rather than risk it for $100
In theory yes...but because they are so lite and don't always fit tightly like the stock ones do...all it takes is constant airflow and a bit of bad luck and bang - you not only get your bonnet cracked but also your windscreen - not cheap to say the least...plus, can potentially be dangerous too...imagine driving at 100 km/h plus and then the bonnet flies upwards and hits you right in the glass...
I wouldn't definitely pay the $240 and get it fitted properly too!
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
