i'm not sure if it'll work because the current tuning they have are in different octane term than ours.
But i could be wrong as i never read anything from the 350z guys using the 350z USA ECU.
PS> I'm guessing you are talking about the ECU not the Dash Computer?
Wouldn't make any sense to use the ECU. I'd say the US dash comp in order to get screen etc in engrish.
I have a US ecu in my 2003 sedan, part of the conversion from 8 speed to 5 speed auto. Type 1
It runs well, good fuel efficiency no pinging. Have not checked on a dyno though.
Need to also think about pollution control differences, my engine light is always on due to not having fuel vapor control. Eventually will find someone to turn it off.
Being 2003 model, only had to get the security number from Nissan. May be bigger issues with later models.
Hope this helps.
  • 4 years later...
hi guys. Has anyone gotten any further with this?
I own a 2003 v35 350GT. I'm a noob in ECU management and interfacing. And would like your opinon/ suggetions for the questions below.
1. Are the ECU's for the M35, V35 and 350Z similar?
2. Are these ECU's interchangeble after tuning?
3. My ECU/ OBD currently talks Consult (or so i have been told). If i could change the ECU, would the OBD connector then talk in the standard OBDII ? (I would love this, as i could then use my android tab with the Torque App)
Any advice is appreciated.
What's the point?
Are you trying to tune, or get a replacement ecu?
Even within models there are many multiples of ECU part numbers, there are awd models, auto, manuals, etc. I don't see a lot of compatibility happening. The computers are physically the same for the vq35 models, and any model of that can have the program ripped, and sent to Uprev to decode and provide a tuneable file.
hmmm...thanks for that info mate.
the only question i have left is, what's the best way to display live Engine data while driving? I was looking for something like Torque or similar on Android.
Any specifics will be great.
hi Scott,
mate are you sure that a standard OBD EML327 cheapy from ebay would work on my 2003 Skyline V35 350GT ???
any specifics i need to look out for on the Torque App? only asking, coz i have tried a fair few times on my Samsung tab 3 with a ELM OBD Bluetooth thingy. I doesn't read the protocols and keeps going round in circles.
hi Scott,
No idea, all I know is the 3.5L was able to keep being produced after 04 due to it being OBD2 compliant, unlike the VQ25. I assumed the standard OBD2 readers would work.
If they don't you are stuck with the usual Greddy touch or HKS OB link units, both of which work on the 2.5det. I have an OB link here I am trying to sell actually. Check it out.. ;)
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
