It has been rather unclear what ARP-studs to use for the main bearing caps on the ca18det. I made an extensive investigation and can now confirm that the kit 165-5402 is a 100% fit.
  • Like 1
That looks like a great build!
Its a massive shame its in sweedish, becahuse there looks like there is a huge amount of information there that seems interesting and quite helpful too!
Just a couple of questions,
Whats the car going to be used for?
And why stick with the CA and not go SR?.. I suppose less poeple run CA's so its a little more different..
Edited by GTS4WD
