  • 3 weeks later...
  • 3 weeks later...
At last, a major problem has been solved.
Earlier I used Aeromotive fuel filters with 10 micron filter elements and they blocked up very fast due to the small filter housings. I had to install filter elements with a coarser mesh and I did not feel particularly well about it.
Thanks to Creatix I got hold of much larger and very hearty AEM filters that remove all particles down to 7 microns without being blocked. Very good!
They also flow through a proper amount of fuel. How about 2800 liters/h at 3.1 bar :D I like!
Tucked the harnesses both sides to avoid shortage and tyre rubbing when the ride height is adjusted fully down. I also temporarily put on the newly painted fenders. Top notch paint job Thanks to Thomas thanks.gif
Sometimes it is Christmas more than once in a year.
I mounted the newly painted parts and also assembled the two Bosch fuel pumps in their bracket. Then something happened...
I did something more... ;)
But....?
What now...?
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
