  • Replies 70
lol brandon is giving such technical advice now..
rofl hahaahah u make me laugh..
yea sure dan take a gutted cat.. your car will pull so much attention im sure cops would love to bend you over each time and always get you for something
im getting a hi-flow 3" magnaflow ceramic cat installed today at PCE Performance.. quite cheap too
Hmmm pull more attention from something that is imposable to see without taking the exhaust off ?????
Please explain oh knowledgeable one !
I've heard gutted ones before and even decat. They're not as bad as you think. Its really only when you slam the accelerator it becomes really loud.
Dan: make sure its a direct replacement to your car too. Even if its cheap, I wouldnt wanna waste time mucking around trying to get it fit.
i guess u never stood near a car with a gutted car whist its on?
or heard a car with a gutted cat??
try not to be smart ass :P
Edited by Redsuns88
+ 1
Very easy to tell.
All they need is suspicion and they can take your car off the road for an inspection at their insp. station.
Then its up to around a $10,000 fine
Pretty sure he's talking about noise level there. But like mentioned heaps before, unless you've got a custom exhaust system, its very hard to meet the 90dB requirement anyway if you remove restriction to your system.
+ 1
Very easy to tell.
Easy for ppl who know modded cars . . . .
Not easy for traffic cops . . . . (or have myself and 2 mates that run gutted cats just been lucky when pulled over?)
Nothing to do with noise. It's the smell and gas flow that give them away
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
