Hi guys,
im just writing this to thank my employer Selbys sway bars for giving me full sponsorship and support at the drift nationals back on the 20th as with out there help i would not have been able to enter the last drift competition held at Oran Park.
Selbys are under new ownership (Bob Tait)and the name superior suspension does no longer exist its just now Selbys sway bars.
We are still in the old whiteline building and the same staff that where making the sway bars even in the whiteline days are now making the new and improved Selbys sway bar.
All the sway bars now come in charcoal metallic pearl as the new colour and all nolathane bushings come in yellow.
At selbys we offer any type of sway bar to suite your needs wether it be a larger diameter than we or other companies list or you have done an engine conversion and need to clear a sump etc .
We can make a custom sway bar to suite what ever your application.
All sway bars come with all the hardware ,bushings,brackets or links to make the bar a straight fit to your car.
If you have anymore queries or would like to order a sway bar give me a ring me Wayne 0296030100 or visit the website www.selbys.com.au
Get behind an aussie product !! Selbys have put back into motorsport and even helped by entering me in events and in the future with growth im sure there will be more on offer
thanks
wayne
img-resized.png Reduced 82%post-66984-1254179472_thumb.jpg 800 x 534 (161.55K)<script type=text/javascript> //
img-resized.png Reduced 82%post-66984-1254179522_thumb.jpg 800 x 534 (138.75K)<script type=text/javascript> //
img-resized.png Reduced 70%post-66984-1254179554_thumb.jpg 500 x 334 (111.23K)<script type=text/javascript> //
Edited by wayne bolton
https://www.sau.com.au/forums/topic/289935-selbys-swaybars/
good to hear the brand is still alive. its great to have a source of custom sway bars made in aus.
i've got selby front and rear bars in the sports sedan, designed directly for the car and it's use.
https://www.sau.com.au/forums/topic/289935-selbys-swaybars/#findComment-4852988
do you guy do different suspension bushes or just sway bar ones?
At this stage we are building the company Selbys back from when it was linked to superior suspension(they no longer exist now).
We are just speciallising in swaybars and custom work and we do all bushes and links associated with the sway bars.
Over time we are looking into expanding back to doing more in the suspension market.
We also now deliver world wide and seem to get alot of intrest and average 1-2 bars a week overseas mainly to America and Canada
https://www.sau.com.au/forums/topic/289935-selbys-swaybars/#findComment-4853638
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
