NISSAN SKYLINE R33 SERIES 2 GTST
$10500 ono
Rego till 27th November 2009
First owner in Australia.
101,200kms, manual, RB25DET
Car is stock other than items listed below:
  • Front Mount intercooler
  • Sports Exhaust with Cannon
  • Blitz Turbo Timer
  • Brand New 18inch Wheels & Tyres
  • Pioneer Head Deck with 6inch Pioneer splits in front, and 6 x 9 in rear, with Sub and Amp in boot
  • 4 point alarm and immobiliser
  • dash mounted boost gauge
This car is my pride and joy, but due to promotion at work I now have a company car and am sad to see it go.
Any serious offer will be considered.
FOR MORE INFORMATION OR OFFERS PLEASE CALL OR SMS JUSTIN ON HIS MOBILE 0421 498 832
Edited by j_dewhurst
$10500 ono
Great looking car but it's not a series 2 it's a series 1. Series 2 don't have the rear windscreen wiper.
true looks the goods, and is clean for one of these!~
oh but no colour coded rear skyline garnish, 'rounded corners' bonnet and s1 headlights?
it is a f**king series 2 you gooses, its my f**kin car i think i would know what it is
Are you on drugs?
Of course the Series II has a wiper, I've got the last of the Series II (1998) and it has a wiper!
  • 1 month later...
Are you on drugs?
No i'm not on drugs. My mate has a 1997 r33 series 2 and it has no rear windscreen wiper and another mate of mine has a series 1 r33 skyline and it has a rear windscreen wiper. Or it could be a series 1.5.
Edited by Fliggy
Bonnet, headlights and front bar are all series 2.
Maybe "one day" when you buy a Skyline you will be in a better position to comment........tool!
Mate, I'm not going to flame you...but you're absolutely incorrect. All R33 Skylines have rear wipers unless removed. With exception only to the GT500 race cars in Japan (and as I said, only if removed).
Done. Resolved. Move on. Free bump to poster. My suggestion to you is put up an ONO price bracket or you'll get dreamers and tyre kicking offers all day, every day! :blink:
  • 2 months later...
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
