I wouldnt mind a 260RS! but I gotta get an auto cos wife needs to be able to drive it...
just do what i did, sell the wifes auto car and buy her a manual stagea, she had no choice but to learn then! :D
Hey Guys
thanks for all the volunteers to help. The car is in some sort of warehouse.
I paid for an inspection done by Motacheck yesterday.
The car isnt quite what i'm looking for so I wont go to adelaide this weekend.
Main thing is the suspension is so low it bottoms out over smallish bumps. Rear is unstable when driving... inside tyre wear on front tyres... in my opinion could have been a car setup for drift... could explain the replaced front bumper and rear tyres had much less tread left than fronts. Everything else about the car is good though I am a bit fussy.
Today I'm bidding on a grade 4.5 ARX with 28,000ks on it!
cheers
Wil
4.5 is great. Good luck with your search :rant:
Be sure to let us know when you get one...you wont look back!! :ermm:
4.5 is great. Good luck with your search :D
Be sure to let us know when you get one...you wont look back!! :(
Apparently it was an over rated 4.5, drivers seat had evidence of a big bubba who squashed and worn the leather.
Got passed in at my max bid, only need to go 60,000 yen more to get it but decided against it... it would have ended up costing way past my budget.
Update on the Sinergy ARX, they gave the rear a wheel alignment and the inspection guy went back to drive it, he said it drove heaps better rear wasnt unstable... Still i'm not keen on the ride height ... its apparantly 15mm lower than standard... bs
Today I'm negotiating a grade 4 ARX with 39000ks on it :merli:
Today I'm negotiating a grade 4 ARX with 39000ks on it :D
:merli:
If it was 15mm lower than standard then it would still be 25mm higher than a standard RS/RX and certainly would not be scraping
:P
ns salesmen will say anything to sell a car!
even after the inspection when i told him it had aftermarket suspension he still insisted it wasnt! Then i said Ohhh yes it has, the photos of the springs say RSR... then the penny dropped.
I have made a deal with North shore Prestige's arx today and put down 1k deposit!
Ben is a champ!
Today I'm negotiating a grade 4 ARX with 39000ks on it :P
I believe the 4.5 refers to the exterior + mechanical condition. They have a separate rating for the interior, usually A, B or C (not sure if there's also D, E etc). Mine was actually a C interior due to a couple of cigarette burns in the seats but other than that it is spotless (I had it inspected in japan before placing a bid so it wasn't a gamble).
I actually saw the sinergy one, they have another yard on north east rd which I've been past a few times. That car's been sitting there for a while (over a month).
congrats on the NSP one. enjoy :(
Congrats man.
What are you upgrading from?
Had an R33 Gts25t, sold it before i got married... been driving wife's mazda 2 for too long!
Saved us a lot on petrol though, and it's amazing how much u can fit in them but its time to upgrade. I'm sick of not being able to overtake cars on the freeway simply cos i cant accellerate fast enough...
lol... you need to talk to Nickcorr about upgrading from an R33 to an M35 (assuming your R33 was stock).
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
