Hey guys,
Me and the jeef have just moved into a new (10month old) town house in Wilston (10 minute train ride from the city).
Unfortunately our previous housemate bailed so we have two rooms spare! (Currently have computer and stuff in one of the rooms but can be easily relocated!)
House is a short walk to the station, 2 mins walk from the Wilston restaurants and 5 minutes walk from the Windsor home zome shops (Subway, Gym, Hardware store, Homeware store, Pet store, Fish & chips etc etc..).
The house is a 3 Story town house with 3 bedrooms and 2 Bathrooms upstairs, big living area & extra toilet off laundry in the midlle level as well as two balconies and undercover courtyard etc, Has a double garage downstairs but it's taken up by the 34 GTR and my girlfriends corrolla, but there is parking just infront of our unit inside our complex...
All rooms come with build in cupboards and fully ducted aircon.
We have ADSL2+ and foxtel already installed :P
Rent is $150 p/w with 4 weeks bond ($600) to be paid with all bills to be split equally.
If anybody is interested or has any further questions you can call/text me on 0420 553 651 or Jem on 0439 030 995 to organise a time to come check things out!
Cheers guys!
Markus
https://www.sau.com.au/forums/topic/291291-housemates-wanted/
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
