Raws car
1992 R32 Gts-t
Auction grade 3.5 car
100,000 on the 25 package
motor was rebuilt with new rings and bearings before fitting 20,000km ago
VG30 op6 Turbo (larger rear housing same as r34 gt-t)
New Arp headstuds
New timing belt
pod filter
Tomei 256 Intake cam
New Tomei 1.2mm metal headgasket
New front mount intercooler
full exhaust turbo to tip
full type M body kit rear pods etc
New extreme heavy duty clutch
New D1 strengthend shifter (same through just more postive feel)
Non Hicas S13 rear craddle
Alloy craddle bushes
coilovers
New Section rear camber arms
Ikea Formula Traction rods
New Kts tie rod ends
New Ikea Formula tie rods extra lock!
New Kenwood head deck
New Alloy Steering bush
New Nolthane Steering rack bushes
HID Cats Eye headlights
Gtr fuel pump
new clutch master cylinder
New front Brake pads
all new fuilds engine oil, brake fuild, clutch fuild, gearbox oil, diff oil all changed 2,500km ago or less
Alarm , keyless entry
custom tailshaft
custom gearbox mount
rb25gearbox
Pioneer 6inch speakers front and rear
Pioneer amp
Front slotted rotors
solid engine mounts
Jjr engine daMPNER
Front strut brace
Battery mounted in rear
New battery
Greddy stytle plenium
Nisno fuel pressure reg
Turbo smart fuel pressure gauge
Autronic smc computer
$9,500 firm SA Strathalbyn 0431 540 141
https://www.sau.com.au/forums/topic/291448-r32-with-rb25-sa-9500-firm/
