hey guys i am running a driver training session at RAC driver traing center on 7th nov for a am session if ur interested pm me for payment details there is currently 6 spots left get in quick as they will fill up quick i will add ur name to the list once i recieve payment
Date: 7th nov
Time: 8am for briefing 830 (if not there for briefing u will not be driving)
Cost: $90 (a few dollars from each person will go to support a club i am associated with WCC)
PAID SO FAR
Myself Scott R33 S1
Alix HR31
Allen 2LV8ETR
Brett V8EATER
https://www.sau.com.au/forums/topic/291485-driver-training-7th-nov/
Date: 7th nov
PAID SO FAR
Myself Scott R33 S1
Alix HR31
Allen 2LV8ETR
Brett V8EATER
Count me in. Pm me the details for payment.
Mark R32 GTS4 4DOOR.
Do I need to go out and buy a helmet?
