hi i was just wondering with the silicone hoses do they do anything to the car or are they just for looks?
i tried searching it in the search but i couldnt find anything about the silicone hoses so i just thought ill post one myself.
https://www.sau.com.au/forums/topic/291524-silicone-hoses-question/
silicone doesn't 'balloon' under high pressures like nitrile rubber hoses do. this is one of the reasons standard hoses frequently 'blow off' when you up the boost pressure- the constant expansion and contraction of the standard hoses contributes to this. this is especially annoying when it's the intercooler inlet/outlet pipes. over-tightening the clamps to compensate won't help
silicone hoses with proper constant-tension clamps are a must if you're chasing big power with high boost levels
but for N/A, probably largely a rice mod...
Peter, are you talking about the silicon hoses used primarily in turbo applications, or silicone radiator hoses?
just the normal silicone hoses that makes the engine look nice. does anyone no how much labour cost for puttin silicone hoses in the engine?
http://justjap.com/store/product.php?produ...at=0&page=1
Apart from that all I can think of (at least in an N/A Application) would be your silicon vacuum lines and possibly induction pipe. Messing around with the induction setup on the R34 RB25DE NEO engines isn't the best idea as they're designed a special way for optimum efficiency, and even then a metal pipe would be best.
To swap your water hoses, well there's your cost of the parts, plus your hourly labour rate and new fluids. Besides looks there's really not a whole lot of reason to do it, unless of course your hoses are worn out and you're looking at an aftermarket option, at least in an N/A application anyways. Your OEM hoses are going to withstand the heat easily.
Lets say it takes an hour of labour, you're looking at close to $200 just for nice looking hoses. Better off putting that money towards upgrading the air filter, or add more on top and get a catback system made up and get some real-world benefits.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
