Rb25 Custom Inlet Manifold, 4x Mt/bf Drag Radials On Rims, Blitz Dsbc Sr Boost Contoller, R32 Tomei Headlight Intake
Selling the remaining parts from my project 32
Custom inlet manifold for RB25, modified std runners - old Subzero type one, with 70mm? 5ltr holden throttle body
Includes alloy fuel rail with 75lb ~800cc Holley injectors
Sard pressure reg
Injectors, reg and fuel rail were new, mainfold SH but polished up
$1000
Blitz Duel SBC spec R boost contoller, fitted but as new, includes all wiring etc, $400
Tomei R32 headlight replacent intake, painted black, as new, $250
2 x MT Drag radials, 255/50R16, 80% tread remaining mounted on polished 5 spoke wheels (std toyota of some sort) 16x7.5 + 50?, perfect offset for my 32 with +1 camber for the drags, with wheel nuts to suit wheels, $400
2 x BF goodrich draf radials, 255/50R16, 80% tread remaining mounted on polished 5 spoke wheels (std toyota of some sort) 16x7.5 + 50?, perfect offset for my 32 with +1 camber for the drags, with wheel nuts to suit wheels, $400
Parts in Adelaide but can arrange shipping of all items, emails [email protected]
Will get some pics of headlight and other stuff later today hopefully, cheers
pics of head light intake? very keen
Will find out for you, can you please pm me address or at least post code, thanks
keen on the rims and tyres mate how much would it cost to freight to gold coast?
cheers
Pics of intake and the 2 MT drag radials, the wheels and the condition of the BF ones are the same, just need to dig them out to get some pics
To clarify, Spec R? Wouldnt happen to be an Spec R ID?
G'day Mate, would you mind doing me a favour... when the tyres are lying on the ground, how many mm's to the mounting hub face (lying facedown and backdown).
I know you've given the offsets and tyre width etc, but it's going to be really tight on my car, so I'd like some exact figures if possible :whistling:
Thanks again,
Tim
Roy, no its the one in the lower pic, the std Spec R i think
I know you've given the offsets and tyre width etc, but it's going to be really tight on my car, so I'd like some exact figures if possible ;)
Thanks again,
Tim
With wheel/tyre flat on ground,
overall height of tyre at the biggest boldge = 260 mm
ground to wheel mount flat = 180mm
this would make sence, as the wheels are marked +50, half distance is 130 + 50 = 130
They fitted nice on my 32 gtst with camber set as it was, also had adjustable rear camber arms. Not sure if at one point I had to use 5mm spacers to get them to clear with different camber/control arms. But the tyres are worth it by themself so the wheels are just a bonus. Hope this helps
Would this be the right one for an R34GTT or would it be the spec S silly question maybe but I just don't know. :down:
The boost controller will work with any turbo, the spec S uses a different boost control solenoid, the spec R one has a better solenoid to contol the boost, hope this helps, cheers
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
