Well, pretty much I'm done screwing around with my v-spec ii r-tune.
I've only a few more niggles. You can see the missing center caps for one.
I need a new battery.
I'd like some coilovers that are up to Ohlins standards but are quiet.
Any recommendations?
Edited by moneypit
https://www.sau.com.au/forums/topic/291820-polished/
Damn, how long have you been hiding this R1..?
I never knew...
Nismo R-Tune R1 + HKS V-CAM, the car must really go hard.
What suspension you got in atm?
I have Cusco's atm but I must say are quite hard, but I felt Tein's are quite good.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4877532
2530s so I think it is 375 kw at 24psi but I have all the original bits so can return
to stock some time.
driving around like a granny it is smooth and quiet which makes the violence when it
boosts even more freaky.
ohlins flag-r and they feel great, not hard or bone jarring, despite having 10lb springs.
but .. they rattle on the mounts @ the rear, and I'm told that is just the way it is. Not
audible when pushing it, just when dawdling around. It bugs me.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4877554
they were installed replacing s-tune, and two different places said I'd have to live with it, Croydon was one of them.
but on another forum someone said they cut out rubber from a mat and used that in the mounts
somehow! (not flag-r but other Ohlins). Would be a shame to give them up if its just one fix away
from being done.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4878298
^^ Nice!
Built / Imported from Nismo Factory yeah..?
Have you got the rear coil overs checked out to see what the rattling noise is?
All the Nismo S1 and R1 engine builds come right out from the Omori Factory and a special build plate can be seen on the right strut tower.
I'm so jealous Justin, I've never seen an R1 engine before but plenty of S1's. I'll pm you about meetup soon and talk about my coilovers I use.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4878610
Yeah I knew that, what I was trying to ask was did Moneypit import it directly from the Nismo Omori Factory or was it bought from an Import place.
I should have explained myself ;):down:
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4879587
it is a zele car, the original owner had omori do the R1 conversion in 2003. I think if I was in Japan with a mint R34 I'd do the same. For the price you can screw up in far greater style by going to some tuning shop or another. And the car is very much still as tractable as it was stock.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4880301
I'm going to take it to tunehouse in a couple of weeks, and see what they recommend.
To get a 2nd opinion yeah..?
Ohlins are nice and IMO, no suspension should just rattle and have to live with it.
Yeah you put up with the bumpy / hard ride but noise wise, gota be checked out.
https://www.sau.com.au/forums/topic/291820-polished/#findComment-4883437
    • Would be easier to just run the RB25DET gearbox, all you would need to do is have the tail shaft / prop shaft shortened. S15 uses the rear ABS diff sensor for the dash speedo, so you can skip using the gearbox speed sensor.
    • Was the failed sensor by any chance this one? Did it just fail or start pissing on itself? I ordered one too, for fuel pressure monitoring, and now I am hesitant to put it in, hehe. Where did you find a brand one?
    • You'd be insane, when a brand new 8HP is ~$4k, and all the work to put a 6 in would cost the same as an 8 and the 8 is a completely established swap. If you think that getting a cheap Falcon box is going to make it a cost effective exercise, then you're not accounting for the extra $10-15k that the task will consume.
    • any further information on this? also interested in putting a zf6 in behind a rb30!
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
