that was a theoretical statment, they may be. Personally i don't like the sound of rebuilding and engine <100,000km's so i'll never play with them. But i shouldn't actually say never becasue the do make huge power considering their displacement.
  • Replies 14.2k
Tell her that it is a 2 storke engine (Even though it doesn't have any strokes), so in effect it'll use twice the fuel that a regular 1.3 litre 4 stroke engine does. It's also why they are rated at 2.6 litres when compaired to piston egines and why they make so much power from 1.3 litres.
told her that. she looked at me like id just asked her the square root of 16 billion.
theyre pretty average on fuel. lowest ive seen the consumption for one in town/suburbia (where she and most people will use it) was about 10l/100km, highest was in the 20's...
as for the rebuilding engines every 100,000km, very true for the older design engines (fd and older), more so when theyre boosted and modded, but not so true for the new peripheral port engines they use in the rx8, service life is a lot more generous.
... but its also a lot less exciting.
Edited by scandyflick
"lol"
:lol:
:D
:O
I thought that you couldn't type in the emoticoms but it must just be that there isn't one for :lol:
Oh it's 126491.10640673517327995574177731 by the way but i did use a calculator. :P
Edited by D_Stirls
I would've thought closer to 3.9L
http://www.skylinesaustralia.com/forums/Ro...ck-t287781.html
Knock yourself out on that thread... :D
on the topic if rotories, id love to have one of these;
with a 20b twin turbo itd rival both my old celsior and the 200 for fuel consumption, but itd be a great cruiser.
its the same old thread as every other rotang thread.
"rotors suck, why?"
cue jokes about busted seals and the rspca.
argument about why everything else a superior engine and that rotors sound like bad gay sex.
finish with something about an ls1.
i just saw the 3.9 litre bit but i think that is a crock, they only use 1 side of the rotor each power (Stroke) so they are only using the 1.3 litres. that's like saying that a 2 litre engine is really 4 litres because the pistons sweep 4 litres per full cycle.
Also that bit about gearing up the eccentric shaft 3 times to use regular gearboxes is also grasping at straws. They use a 3 times gear up because the rotor has 3 sides, so him saying that they could step it up to 6:1 then there would have to 6 sided rotor which would be huge.
Edited by D_Stirls
uuuugh.
itunes just decided to purge 80gb of music from my ipod.
now for the tedious task of reloading all that music from about 12,000 different sources (3 hd's, and a couple hundred cd's...)
235's all round could work. but im not lowering it more. low enough as it is. srs. exhaust scrapes and front wheels scrub as it is.
lulwat? What are the wheel and tyre specs on the one in the pic?
Tuck the exhaust up and roll the front guards and maybe a slightly narrower tyre and you will be able to go lower to end up with the real shit fitment wise, or just pull your guards a bit so it reps flushness and doesn't look so cop-happy.
I have nothing against rotary engines, in fact I love them and the sound they make, but I have to agree with the whole 3.9L displacement argument as each rotor has 3 combustible sides to it for every one rotor revolution (not crank or eccentric shaft revolution).
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
