  • Replies 14.2k
vu upgrading performance? why? hes selling all his performance parts...
Never really understood that design but then again I suppose it's necessary to accommodate for the SMIC
again, look at the sr, runs a peasant smic, but has a non retarded plenum.
[*]Front pipes (No I'm not going to AM Performance) - If you're not going to listen to heaps of people recommending you see Andrew, I won't answer this, he is cheap, does quality work and his service is second to none
+2. I did my research before going for the AM products and frankly nothing can come close unless you're willing to spend mega bucks on HKS or Tomei, then again I wouldn't know if these are any better because frankly I wouldn't fork out that much dough for something that realistically can't make me huge rwkw on it's own :P
Do as i did. Buy second hand HKS dumps, less than half the price :P
well he had a 33 gts-t, so upgrading performance and model could be 33gtr, 34 gt-t, 34gtr, v35, r35 :P
True, but have a look at the last 10 or so pages here.... too obvious :P
Chad, I thought about it and no one and I mean no one had a HKS dump for the RB25DET. Even for Streeter to get me one from Japan s/h was going to cost more than the whole AM dump/front.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
