  • Replies 14.2k
i send message and find out
dave, you worry me
and brendon (STILO), i see you lurking, you new south wales come victorian mexican :P
hey man go easy, i did live in SA too once but not long enough to pick up the pommy accent
Edited by ST1LO
ROR Ruby on Rails
ROR Reach Out and Read (national pediatric literacy program)
ROR Rate Of Return
ROR Rotate Right
ROR Retinoic Acid Receptor
ROR Rise of Rome (Microsoft supplement to Age of Empires game)
ROR Rules of the Road
ROR Rate of Rise
ROR Revolutions On Request (artist group; Finland)
ROR Return on Relationships (value of relationship marketing)
ROR Range-Only Radar
ROR Raffing Out Roud (Laughing Out Loud in Scooby Doo voice)
ROR Reservation of Rights
ROR Repair Of Repairables
ROR Right of Rescission
ROR Reggae on the River
ROR Range Only Radar
ROR Released on Own Recognizance
ROR Rise Over Run (online magazine)
ROR Rigs of Rods
ROR Koror, Palau - Airai (Airport Code)
ROR Relational Operator Replacement
ROR Rollover Risk
ROR Run Off River (hydroelectric power systems)
ROR Rachunek Oszczednosciowo-Rozliczeniowy (Polish: Current Account)
ROR Record of Revision
ROR Repository of Record
ROR Room Over Room (game engines)
ROR Registry of Resources
ROR Record of Reference (Intel)
ROR Returned or Refunded
ROR Radiological Occurrence Reporting
ROR Realm of Ralnar (game)
ROR Route Overlap Reduction
ROR Routing Overhead Rate
ROR Regimental Orderly Room
ROR Realms of Renth (forum)
ROR Royal Order of the Rabbit (Gram Rabbit fan club)
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
