  • Replies 14.2k
so u wanna give me ur intake pipes yeh?
haha, like i said to the other luke, im more then happy to get them copied and re-made if your interested in them.
wouldnt think that would cost a whole lot to re-make? just cost of stainless pipe work would be the most as well as the welding for the merge pipe.
let my know dude, would have to be on a weekend though.
No, I'm definitely first in line! :bunny:
And you'll be back Kye
lol, i wont be out of it for too long. the only reason i'd sell both cars is for a certain other car.
it's not a nissan though, but i would enter more sau grip days if i was to get it ;)
so, who's going to the ns christmas cruise? looks like i might actually be able to make it, working a 60 hour week leading up to it though, so the 200 will probably still be dirtier than lukes mind...
it's not a nissan though, but i would enter more sau grip days if i was to get it :bunny:
My guess would be an Evo...
thatd be my guess too.
Looked like nismo to me from memory :bunny:
Last i spoke to Matt he said it was a set like this http://cgi.ebay.com.au/Nissan-Skyline-GTR-...=item3ef1a37d85
Unless it was changed at some stage.
Edited by DSTROY
chad, looks like that one from ebay. at least kinda the same...
luke, if you want to borrow them your more then welcome too. i need the car to get to work and back though so on a weekend would be the best bet.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
