  • Replies 14.2k
I wrote this up for when i sell my s13 but since I've been asked about it a few times already without putting it up for sale heres the specs
YEAR 1989
MAKE Nissan
MODEL S13 silvia - resprayed custom green – manual
MODS
Ca18det
engine has received a full o/haul and metal head gasket
kkr 330 turbo fully rebuilt with garret gt28rs internals
supra front mount with custom piping and custom intake pipe
speed lab remap
gtr fuel pump
poly urethane engine, gearbox, and sub frame mounts
gtr rear sway bar
cusco camber and toe arms
moon face traction rods
poly urethane castor rod bushes
ram rear coilovers, gab front coilovers
lock spacers
brand new exedy clutch (seen 3 track days)
new clutch master and slave cylinder and lines
full turbo back exhaust
drift handbrake button
cusco mech 2 way lsd (also seen minimal track time since new)
skyline rear 5 bolt drive shafts
obx bucket seat
clarion head unit 45x4 and clarion 6x9 speakers
16x7-0 and 16x8 +2 ssr xr4 longchamps
Pink steering wheel (straight from japland :P)
Front lower lip
Front and rear strut braces
52mm alloy radiator with all new JJ silicone piping
EXTRA COMMENTS car is fairly straight with the body work could use a little tlc, chassis is immaculate with no rust or dents in the floor pan, it made 176rwkw with the retune and has more in it if the injectors and AFM where upgraded, basically a tough street car with plenty in it for drifting.
This car has seen track time but not much at all. 3 times since January is it and it doesn’t get driven unless its going to the track. I do start it and roll around the winery where its kept in a shed at least ones a week to keep it healthy.
nearly tempted to throw in my build for that lol
cant really afford it tho :P
in parts is prob worth 8k with the rebuild otherwise id sell cheaper but just to much put init.
been told its the best sounding ca heaps of times too, pops decent flames and proved itself on the track.
have think about it dude, could be cheaper in the long run insted of building a car from scratch and this ones got some decnt stuff onit to get you started :P
heres some pics to get you thinking. its before the paint job though.
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
