Can anyone open this link?
http://www.skylinesdownunder.com/forums/ar...hp/t-51894.html
Its the details for a manual conversion. I could open it Friday, but now I want to print it, it won't open anymore? If anyone can open it and save it as a PDF that'd be great.
:nyaanyaa:
  • Replies 14.2k
http://www.inthemix.com.au/news/aust/45086...resented_by_ITM
Ooooooooooooooooooooooooooooooooooohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
hhhhhhhhhhhhhhhhhhhhhhhhhhhh shit...
Seeing them at Future's and now this! Fuuuuuuuuuuuuuuuuuuuuuuck yes!!
First 3 months of 2010 for me: Sensation White, Summadayze Melbourne, Midsummer Circus, Big Day Out, Tiesto in Melbourne, Future Music and then Prodigy sideshow in Melbourne.
You're only young once!
well where was my invite mofo, its cause im only a half cast isnt it krishy
thats correct.....your not chocolate enough brew....i had a awesome deal through my travel agent.....and the trip was well worth it....gota do something like the SAUSA smashes gold coast or something.....
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
