  • Replies 14.2k
All you need Norman is 18x9.5+22 on the front and 18x9.5+12 on the rear
http://www.skylinesaustralia.com/forums/Of....html&st=40
http://www.skylinesaustralia.com/forums/po...904341-59878934
That is
18x9.5 +12 all around
F: 225/45/18 -1 camber
R:245/40/18 -2 camber
But I'd run 235/40 rear and 225/40 front.
im unsure about voting nothing has bee really said about it
An invisible voting poll will be set up next week in the form of a new thread in the member's section Steve.
In the meantime, we're encouraging members to nominate other members, with their permission (or yourselves for that matter) in the thread that Andrew created today.
You can put your names down for any position whatsoever.
i hereby nominate steve for the missionary position >:thumbsup:
-D
whats ya mate's name? not pete by any chance
you got it in on matty, worked with him for 5 years at munno, now i see him out on the
road as a merchy for schweppes..
well, chad is buying the drifteks, so ill be grabbin the sparco's on tues-wed
oh yeah, bought the NICS motor out of the silho when he did the 25 conversion all them years ago
hehehe that thing got a good caining :thumbsup:
the good ol days when i used to live out @ lewiston.
srsly, am i doin the right thing with these rims? anyone?
i think they look sweet, with more pump n stretch.
