  • Replies 14.2k
Some of us dont earn enough per hour in normal time that they have to do copious amounts of OT :ermm:
I hear that! This was my first whole weekend off from working in gosh darn knows how long lol
so... in 28 days ill be losing my licence. bit of a bummer. but they couldve raped me pretty hard.
copping a 6 month suspension and a $600 fine. but considering what they couldve done me for, that isnt too bad.
Excessive speed, I'm guessing?
yup.
This mean the S14 is being sold? or copping epic mods while non license?
probably being sold. plan has always been to sell it this year. just means im more likely to do it if i cant enjoy it more than once or twice (track days) for 6 months.
Yeah I got done for excessive speed early last year. Lost mine for 6 months. Plus you get hit with 6 demerit points.
I was lucky as the cop was going to take me to court to throw the driving without due care and all the rest, charges onto me which would have been much worse! And I didn't want to go to court again, seeing as I've already been to contest my "Not wearing a seatbelt in the back seat and receiving 3 demerit points for it even though I wasn't driving" fine.
But... you live and learn :( none of us are angels on the road regardless if you have a GTR or a Excel.
pretty much. i think the only reason i got away with only the excess speed charge (and not manner dangerous, speed dangerous, court appearances and whatever the f**k else they thought to throw at me) is because they cant 100% prove i was driving, and i rocked up for an interview or whatever as soon as i possibly could. if i hadve waited for a summons, i probably wouldve been raped.
