  • Replies 14.2k
think i need to clean the rubber off the Ceffy and you can see where i gave the tyre's a tap coming onto the start/finish straight, fair lucky not to lose the rear bar.
Edited by DSTROY
Gtr as a daily 34 as a project.
theres several interesting 32 gtrs on carsales atm
one is #78 of the original aussie delivered 100
one is a tommy kaira spec 32
and another has only 9800km on the clock...
whats ur budget? :D
-D
whats ur budget? :D
-D
I so wouldnt mind that TK R32 GTR... but its so ugly and not in my favourable colour.
Excessive lowering will give you too much toe in, unless you have adjutable upper arms
stock suspension now and stock arms
only adjustables that were in it were coilovers and rear camber arms
will have to put hicas back in
could that be the problem?
Proves that you are driving it properly!
it can affect hicas if the toe is greater than 2' on either side, the hicas computer senses it somehow and disables hicas after about 15 minutes
for what its worth, i got some rear adjustable upper control arms last year for around $350 and the precise adjustment that the aligner was able to make more than justifies the cost... makes the car perform much better with less tyre wear to boot ;D
not regency friendly, but theyre easy enough to get engineered
-D
-D
i think you'll find what ive had to remove :D
Is that all?
*sigh* its enough to throw his geometry all out of wack again
he has the front castor arms, the rear camber arms, the adjustable suspension... all 3 things that work in tandem to ensure the suspension actually works properly
u should enquire about getting that stuff engineered man, rory thompson does it for $500 odd if I recall correctly, and that mean you could continue using the control arms for caster/camber... not the suspension but eh, 2/3 is better than nowt
-D
Yeah my suspension was out of whack when I removed everything for regency, handled like a bucket of shit on the way to Tyre Power for an alignment which straightened everything out and made it feel perfect again afterwards.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
